Can anyone help?
With all controls off, after a couple of minutes both the venting fans at the back kick in. i could hear a click from the temperature limiter at the top front. If mains power turned off after a few minutes you will hear another click. If you power back up the fans will now be off for a few minutes. There is live power to one side of the limit stat which powers across when you get the click. I replaced this temperature limit stat, but no difference! Should there be a live at this stat when off? if not I would suspect programmer or selector, but any help appreciated.
Gary
