Neff U1422n0gb/03 main oven switch pushed in
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff U1422n0gb/03 main oven switch pushed in
  • #86304
    Simon46
    Is it true that I have to replace the front facia panel 00443925 to clip the main oven selector switch and thermostat that has been pushed into the oven? Tried glueing it but no good.
    £168 quid!
    #430762
    aqualectric
    Re: Neff U1422n0gb/03 main oven switch pushed in
    Can’t see what you mean – is the selector switch mounting bracket bonded to the glass control panel? The control knobs of this design seem to collapse inside themselves and some are obsolete. (quick Google Images search and there’s loads of new old stock out there!) If the bracket is bonded (don’t remember seeing one like that though..) then use the 300 degree silicone used for mounting the oven glass door panels; that should do it and it’s heatproof.
    HTH,
    Steve.
    #430763
    Simon46
    The mounting bracket that 00425173 clips onto is not showing as a spare part. I might try supergluing it into front panel and then siliconing it to the panel then clipping in the heavy selector switch and thermostat to it.
    Many thanks Simon
    #430764
    Simon46
    Well it worked. Superglue to attach it to facia then siliconed in hairdryer to warm it then finally clipped selector /stat assy to front panel. Made a support to hold the stat up whilst it set which was left in oven.
    Many thanks Steve
    Simon
