Neff U1451B0GB/05 oven handle
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff U1451B0GB/05 oven handle
  • #86698
    Skippywhitefiend
    I need some help please in fitting a replacement handle to a Neff Neff U1451B0GB/05 main oven door. I’ve got a replacement handle and it looks like you have to separate the oven door inner and outer to get at the screws that hold it in place. So I’ve got the door off and have removed 6 screws from the inner door – but the metal inner still seems tightly bonded to the glass outer (it’s a bit loose at the hinges end). Could the metal inner be bonded to the glass outer? Any help appreciated!
    #432785
    Re: Neff U1451B0GB/05 oven handle
    no its not bonded
    make sure you have got all the screws
    if so its prob grease
    Skippywhitefiend
    Thanks – I’ve definitely got all the screws, if it’s just grease any tips for releasing it? I don’t want to use too much brute force and break the glass! Ps found a video online for a Neff oven door which has 2 extra screws on the bottom edge which my one does not have, that’s what made me think it might be bonded.
    #432787
    Once the door is removed from the oven then you only need remove the top 2 screws in order to split the panels to change the handle. The bottom 4 screws hold the hinges in place therefore there’s no need to remove them.
    #432788
    Skippywhitefiend
    Mystery solved – there is a very thin gasket between the metal inner and the glass, which must have heat/grease welded itself. I applied a bit of brute force and ignorance by running a Stanley knife inside the glass and the two halves came apart. I did damage the gasket a bit by doing this, but it’s gone back together allright and will hopefully be ok – the gasket looks like it’s bonded to the glass side. By the way you do need to take the hinge screws out, as the bottom of the hinges slot into brackets which are glued to the glass. Probably when new you can then slide the metal inner downwards (towards the hinges) to get the halves apart. Thanks for giving me the confidence to do this – I was convinced they were glued!
    Cheers
    Patrick
