Neff U1451N0GB/05 Elements
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff U1451N0GB/05 Elements
  • #87094
    nickneff
    Hi , I have a Neff Oven, U1451W0GB and the main oven elements are both open circuit. Am I right in thinking the circular one around the fan is only what is used when using the fan oven which is what we normally do. Could it be the top one may well have been faulty for ages without us realising ? Are there any factors which make the elements go quickly as the last Ego one lasted only 2 years although we do use the oven a lot. Thanks
    #433947
    Re: Neff U1451N0GB/05 Elements
    Generally, unless you use a fan assisted mode with upper and lower in play then yes, only the circular element in energised for fan oven cooking and, that’s the most commonly used method by most people even if the other mode is available.
    They’re a bit like light bulbs… some last, some don’t.
    nickneff
    Many thanks for you quick reply. Hope the new one lasts longer. I have the choice of another Ego or a cheaper Maddocks brand. Is the Ego worth the extra? Cheers
    #433949
    Never had issues with these ones:
    https://shop.ukwhitegoods.co.uk/nf14100 … en-element
    nickneff
    Thanks appreciate the reply.
