Neff built in electric double oven
ENR U1461N1GB
FD 8203
Worked perfectly until it failed during use today
Symptoms :
Clock/timer display is blank
Neither oven heats up
The only sign of life is the orange lamp above the upper oven temperature selector knob. If the upper oven function selector is in the 0 position and the temperature selector is set close to the lowest setting then this glows a little.
Does this suggest the main control / display board has failed?
Many thanks in advance,
Richard
