Neff U1524N0GB/10 , no heat
  • #93882
    smeghead
    No heat in main oven -Fan element ok – (no power getting to element.) fan works & lamp ok
    Also, when you power oven on , display reads 444.
    Selector switch ok, suspect PCB – any thoughts anybody ??
    Thanks, Clive.
    #455822
    ray.t
    Re: Neff U1524N0GB/10 , no heat
    Hi, sure I have come across this before and it was some sort of lock that had been set. I’m sorry I cant remember how I got the lock off but worth checking before you buy a pcb.
    #455823
    ray.t
    Just found this online.
    Using the oven selector switch, switch back and forth from fan oven to conventional oven 5 times until 333 is displayed. Then the oven should work. The display 444 means that the lock program has been initiated.
    Got to be worth a try.
    Ray
    #455824
    smeghead
    Thanks Ray, i tried something similar in house, to no avail.
    The pcb is NLA – so new oven !
