Hi Guys
Yes they are a little pig……
Get the cooker out and take the top off, pull off the control knobs on the affected side.
There is one T20 screw holding in a cage arrangement that holds the 2 display film strips and control switches.
The whole lot comes out as one piece but takes alot of fiddling to get out, I have never had to take the facia off but others may find this easier.
The film carrier is held in with another T20 screw.
The strip has a ‘timing’ notch cut into it that has to be aligned with the carrier so everything displays correctly (Like timing when doing a cambelt on a car!)
Don’t be suprised if your back two weeks later with it broken again, but thats another story…………………. 😡
HTH 😉
Steve
