NEFF: U1661NOGB/02 FD 8201 Oven Door not shutting tight
Home Forums Public Support Forums Help And Support Cooker And Oven Forum NEFF: U1661NOGB/02 FD 8201 Oven Door not shutting tight
  • #88935
    tonyb61
    Hi, we have a Neff double oven, and recently we have noticed a problem that the main oven door is not closing very tightly, heat is being lost at the top and the oven above gets moisture condensing on the front. This implies the oven door seal is leaking, and not very effective ? Is it possible to replace the seal and is the seal magnetic so it holds the door shut or are there other reasons for the door not sealing as tightly as it did ?
    #439824
    LothianDomestics
    Spectator
    Re: NEFF: U1661NOGB/02 FD 8201 Oven Door not shutting tight
    Sounds very like a problem with the hinges and/or hinge receivers.
    #439825
    tonyb61
    Is there any way to identify whether it is the hinges themselves or the receiver ? The neff parts drawings implied the hinge sits inside the oven door itself, and the hinge receiver is inside the body of the oven ?
    #439826
    The hinges hold the door closed against the seal.
    If the seal’s dodgy, it’ll leak condensation especially when cooing foods with a high moisture content, which is most stuff.
    Ditto if the hinges don’t pull the door closed correctly.
    The runners are a possible for sure, but you would expect to find the door out of alignment albeit slightly if they were faulty and nothing else.
    So in order I’d be looking at the seal, then hinges, then runners.
    Some blatant plugs for you but may help in any event…
    Seal for the main oven: http://shop.ukwhitegoods.co.uk/096824-c … eal-gasket
    The hinges are: http://shop.ukwhitegoods.co.uk/267845-oven-door-hinge
    Runners: http://shop.ukwhitegoods.co.uk/172647-o … nge-runner
    HTH
    tonyb61 wrote:Is there any way to identify whether it is the hinges themselves or the receiver ?
    The hinges inside the door usually suffer the most wear meaning the door doesn’t quite shut against the seal at the top. The pivot pins wear within the hinge assembly meaning you need to replace both hinges. Only in extreme cases do the receivers need replacing as well.
    #439828
    tonyb61
    I can see the door isn’t quite closing properly, I can push it closed another mm or so before the seal is tight against the door. Sounds like a pair of hinges is required !
    #439829
    tonyb61
    I sent an mail to the spares email about the hinge part numbers but it was rejected as my isp is on a blacklist I think. So I’m asking via this post instead.
    Regarding https://shop.ukwhitegoods.co.uk/267845-oven-door-hinge referred to above.
    I did a check on the Neff spares parts site oven diagrams and the hinges seem to be handed (00267845, 00481568)
    Is the hinge shown on your site correct and suitable for both right and left hand hinge locations ?
    Tony
    #439830
    don
    Hi Tony
    I’ll point Dave in the UKW shop to this thread 🙂
    Don
    #439831
    tonyb61
    Thanks….
    #439832
    Dave_Conway
    Hi Tony,
    On your version the hinges are different, you need one of each of 481568 and 267845:
    https://shop.ukwhitegoods.co.uk/481568-oven-door-hinge
    tonyb61
    Thanks, order placed…..
    #439834
    Dave_Conway
    😀 Thanks
