Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Neff U172 – New Element fitted but not heating
- This topic has 4 replies, 3 voices, and was last updated 12 years, 6 months ago by
Wandering Wycombe.
September 24, 2013 at 2:13 pm #77311
Wandering Wycombe
ParticipantI have successfully installed a number of replacement half moon elements in the main oven over recent years and have experienced no problems until now. The existing element blew a few days ago. I stripped out the rear panel, removed the fan so as to access the top screw and removed the blown element, which had blown right through the element tubing in two places. I disconnected the two electrical connectors and fitted a replacement copy part element (from same supplier as the failed element which had lasted just over two years). Refitted everything and tested the oven. Fan working fine, oven light on but element not getting hot??? Took everything apart again and, with the element hanging by the connecting wires and oven switched on, I put an electrical test screwdriver carefully onto each connector terminal to check for a 240 volt live source. Nothing found (no neon in screwdriver) from either element connection. I assume a 240 volt live feed should be going to one of the connectors, but could not get the neon lamp to light in my test screwdriver. I assume therefore that as the fan and oven light are working correctly, that the fault is somewhere else, possibly as a result of the element shorting when it blew. Any advice or guidance as to a likely cause and what else likely needs to be replaced would be very much appreciated. Thank you
September 24, 2013 at 2:37 pm #401718Andy jones
ParticipantRe: Neff U172 – New Element fitted but not heating
There’s normally a toc connected to one side of the element. That’s probably oc
Sent from my iPad using Tapatalk HDSeptember 24, 2013 at 4:27 pm #401719Wandering Wycombe
Thanks for quick reply. I will order a new TOC and fit to see if this solves the problem.
Thank youSeptember 27, 2013 at 2:05 pm #401720Wandering Wycombe
Fitted new TOC and oven now heating, but heat not cutting out. I assume thermostat now needs replacing also.
September 27, 2013 at 3:33 pm #401721Martin
Sounds like it that’s for sure.
