Neff U1721 Fan element keeps blowing
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff U1721 Fan element keeps blowing
  • #73220
    kula
    Hi, after about 10 years of solid use, my Neff U1721 fan element failed,no problem I thought so I replaced the said item. However now on it’s 4th replacement in about 3 years, I wondering if there is a particular reason why this might be happening so frequently, normally the elements have completely failed, except the previous element would heat to about 150C, but anything more and the main fuse would trip.
    Any ideas?
    #386798
    Re: Neff U1721 Fan element keeps blowing
    Check the fan motor. Not enough air over it and that’ll happen.
    kula
    Thanks, anything special to look out for though?
    #386800
    Running slow, noisy etc.
    kula
    Thanks, must admit it’s probably a bit louder, not sure I’d know if it was running slower though. might be worth a new motor then perhaps?
    #386802
    you said you replaced the element did not say where you got the spares from
    have had a lot of problems with non genuine spares being poor quality and a short life span
    yours is the semi circle element had a non gen failed while i watched it never fitted non gen since
    gen element number 464643
    hope it helps
    kula
    The first time is went, I bought a genuine Neff part, but that only lasted about 12 moinths, so usually I’ve been forced to buy OEM ones locally, with varying success.
    #386804
    electrofix wrote:gen element number 464643
    I think we are talking those dreaded ‘half moon’ fan elements here Dave where the genuine replacement part number is 360604. In my experience both genuine and pattern half moon elements are equally as unreliable. I would therefore advise the OP to stick to buying the cheaper pattern equivalents and replace them as and when they next blow. I’ve had genuine elements go belly up inside 15 mins and as they are so so expensive it can make a grown man cry when that happens…..pass the tissues.:(
    #386805
    kula
    That’s interesting about the genuine and copied elements being equally unreliable, and yes it’s the dreaded half moon element, probably dreaded because of the pain involved in removing the fan to get at the the top screw. What idiot designed that!
    #386806
    Salsaboy
    hi guy. I have had exactly the same problem with my Neff U1721, last time, at Christmas (christmas day in fact) the eliment blew. It was a genuine part and the suppliers have replaced it. but as this is the fourth or fifth time it has gone. Noe with the dreaded semi circular eliment, I could not remove the fan so cut the top bracket off. Was this a mistake ????
    BUT now I have a new eliment “how do I remove the fan” is this easy.
    #386807
    Pretty easy to remove once you realise the nut has a left hand thread.
