NEFF U1721 oven
  • #36981
    tonytiger1949
    I have a NEFF U1721 oven under a work surface.When I try to use the auito on and off function the oven comes on and stays on and the auto light is not on. Also, some of the digits on the clock can’t be seen.
    I have looked behaind the control panel and there is a unit labelled EL723/007.22A if that is any help.
    Advice would be appreciated.
    Tony
    #253037
    gegsy
    Re: NEFF U1721 oven
    Sounds like a faulty clock unit to me.
    To give more accurate information, we would require the enr number which is usually around the perimeter of the main oven or door; when opened.
    tonytiger1949
    Re: NEFF U1721 oven
    Hi Thanks for the reply
    it’s E- nr U1721n2GB /05 FD 8411
    Tony
    #253039
    gegsy
    Re: NEFF U1721 oven
    Clock unit if required is p/no 432839 and is available from spares@ukwhitegoods.co.uk 😀
