Home › Forums › Public Support Forums › Spare Parts Help › Neff UN1320N2GB top oven
- This topic has 7 replies, 4 voices, and was last updated 15 years, 2 months ago by
AHelli.
January 23, 2011 at 12:22 am #60432
AHelli
ParticipantHi
Can anyone give me the product number for a replacement element for the top oven. I have no heat in the top oven and when I try to put it on it just trips the circuit.
I replaced the element in the base oven less than 12 months ago so I am confident it is the top oven element.
PS the grill is working fine
thanks in advance to anyone that can help
January 24, 2011 at 8:50 am #342120don
ModeratorRe: Neff UN1320N2GB top oven
Can you re check the ENR number 😉 there are no UN models listed but there are U1320 models. You also need to tell us the two digits after the GB part as well please.
Moved to appliance spare parts forum 😉
Don
January 24, 2011 at 10:54 pm #342121AHelli
ParticipantRe: Neff UN1320N2GB top oven
thanks for the quick response
Here are the numbers I have from the plate:
> > UN1320N2GB/01
> > FD8212
> > BAP54-8January 25, 2011 at 8:38 pm #342122don
Was the oven purchased in the UK as it is not recognised as a UK model on the http://www.neff-eshop.com/eshop/neff/gb/indexa.htm
Don
January 30, 2011 at 12:21 am #342123AHelli
HI thanks for the response. The oven was intalled in the house when it was newly built 8 years ago. I did purchase an element for the main oven from you guys approximately in August 2009 and liaised with Dave, please see extract below:
Thanks Andrew,
The element is part number 2044 on our website, here is a direct link to it for you:
In stock, please order online.
Regards
The numbers I gave him are: UN1320N2GB/01FD8212
BAP54-8
sorry if I am repeating myself, please advise where or what else I can check.
Many thanks
January 31, 2011 at 10:40 pm #342124nomadPaul
ParticipantIf its a Neff then the 1st N is incorrect and doesn’t exist in the ENR model number.
Chances are its a U1320N2GB/01 which also fits in with the manafacturing date of Dec 2002 .February 1, 2011 at 1:12 pm #342125Jackal
The part number your after I believe is 358481
Contact Dave on this site at spares@ukwhitegoods.co.uk and he should be able to source one reasonably quick for you, although it wont be the cheapest item on earth.
Good luck and if fitting this yourself, remember to disconnect the unit from the mains supply for your own safety!
Regards
Jackal
February 1, 2011 at 7:52 pm #342126AHelli
Thanks a lot, we got there in the end. Yep I will liaise with Dave directly and order.
thanks again for your patience and help.
Kind Regards
