fitted new soldered motor brushes to this machine (v4380xogb/13) now it washes ok but when it goes onto spin it only gives short bursts of spin then slows down and tries again, suspect module but as very expensive i need to know for sure. anybody else had this fault?
Make sure the pins of the field coil are pushed firmly home.
This may mean stripping the motor down again. If your careful you may be able to do it externally.
