This intergrated washer dryer has had very little use.
When you select a wash or rinse program it starts filling with water but the pump runs all the time.
Have 3 clicks on the pressure switch, pressure system clear, I can find no earth faults.
Wondering if it could be the main power module? could be an expensive mistake though as the board is £224.43 😥
Any advice would be great.
Thanks Graham
Sounds like a sticking pump relay on the power module. I’ve had one of these myself. Usually a sharp bang underneath the machine will stop the pump running, but the next time it’s activated it will probably stick again.
