Neff V4380XOGB/13 Washer
  • #13585
    Toni
    Been to the above machine today to change the motor end frame, module and interlock. The original fault was the module had blown, the brushes are completely worn and the interlock had jammed. All the parts are gen from BSH.
    Now the machine starts ok on any programe but after a couple of minutes it just stops. This happens on the wash & spin programes. The Motor turns a few times before it stops. The heater is ok & pump etc. This is going to cost over £300 so Idont want to loose it if possible.
    Any one have any idea what is wrong? I have checked all the wiring on the module, Motor etc
    Hope you can help
    Toni
    #155545
    BSH-MAN
    Re: Neff V4380XOGB/13 Washer
    Did you correctly code the module?
    #155546
    Toni
    I didn’t realise you had to do anything to it
    How do you code the module ? please 😳
    There was a wiring diagram enclosed but I cant make out any writing in it
    Toni
    #155547
    superfix
    If I remember rightly, the coding instruction is printed on the inside of the box.
    It’s a matter of cutting resistors, depending on spec of m/c.
    #155548
    Toni
    I dont remember seeing anything in the box, but it did come with what looks like a wiring diagram. (Thats proberly it?) but the writing is so small I can hardley make it out (even with glasses on)
    I will try to figure it out, but if anyone can offer any other help, I would really appreciate it
    Regards
    Toni
