Neff V5340
  • #73394
    winker
    Just replaced the drum spider on this machine.Customer siad the clothes were hot and steamy from the tumble dryer side.Everything checks out ok but there is no power to the condense water valve.Any ideas what to check
    steve
    #387348
    Re: Neff V5340
    Was the dryer working OK before you stripped it to replace the spider? If so, a wire break or hose kink maybe? Also, any error code showing?
    #387349
    DrDill
    Re: Neff V5340
    Main pcb
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #387350
    winker
    Re: Neff V5340
    this machine obviously has a very eco dryer.despite checking a dozen times there was no voltage at the condense valve.Been to check again and hey presto 210v (think seb are going eco)
    Hour later E06 pops up.Changed the pump and rechecking dryer now.will let you know but thanks for the responses…feel a fool
    steve
    #387351
    nomadPaul
    Re: Neff V5340
    E:06 ? If the new pump doesn’t work , check You haven’t disturbed or damaged the pressure hose after taking off the front plate .
