Neff V5360X0GB Dryer Fault
  • #32727
    Fairdeal
    Has anyone come across this strange fault on the above model Neff machines?
    the dryer part does not work.As soon as you start the dryer, voltage comes to the element but after few seconds it cuts off but the dryer fan keeps working throughout.
    the element, cutout are fine. I have changed PCB(Main one at the bottom) but no joy.
    any ideas?
    regards
    #236202
    Re: Neff V5360X0GB Dryer Fault
    At a guess it could simply be that the NTC has failed and the module shuts the heat off? Have you checked it’s resistance reading?
    #236203
    Fairdeal
    Hi Martin,
    yes I have checked the NTC that is next to the heater that is fine.
    regards
    #236204
    Fairdeal wrote:yes I have checked the NTC that is next to the heater that is fine.
    The device next to the heater isn’t the NTC but the overheat TOC. The NTC is located in the ducting that goes down to the door boot 😉
