Neff V5360XOGB – drum not moving – help needed please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Neff V5360XOGB – drum not moving – help needed please
  • #78809
    joed
    Happy New Year all,
    My Neff washing machine has developed a fault.
    The other day it was being used as normal,
    when it made a loud bang almost at the end of a program (2m left).
    The machine completed the program but the the drum was no longer spinning.
    I followed various advise online, and when I removed the back of the machine,
    I could clearly see that the belt had slipped from its correct position.
    I got some advise from “burns” on this forum,
    and he recommended I try putting it back on if it was in good condition, which it is.
    So I tried and then I noticed that the pulley on the back of the drum is rock solid, and does not move at all!
    I then tried to spin the drum from the front of the machine,
    opening the machine door, and again the drum was rock solid,
    could not budge it an inch…
    so clearly there is an issue here.
    Also – I have supplied another image – I noticed this pipe is not connected to anything (circled in red),
    which instinctively does not seem right to me.
    Any opinions would be most welcome.
    #406992
    You have probably lost a sock due to overloading the machine and it’s got caught between the drum and tub? The small hose is the pump drain tube attached to the drain filter.
    P.S stick to one thread and don’t open another otherwise it gets messy and the mods go mental. 😉
