The condensing valve is not getting power to it. So it overheats & trips the pushbutton toc.
Tried sensor on heat duct, no good.
All wiring ok, thinking module – cant see anything else that triggers the valve.
Any ideas ?
I think the condenser valve cuts in after 10/15 minutes of drying, I watched this for 40 mins and the valve didn’t cut in.
Even if the condenser was blocked , am pretty sure it doesn’t affect the valve supply.
Thanks anyway.
