Hi Guys
Can you help me with this one. I have changed motor, dryer heater and door interlock and I am still getting E13 error code,it is intermittent some times the washer will work.
There’s only one more possibility really…..and it’s the most common fault of E:13…. The operating module. I believe there’s a capacitor that fails that controls the door lock. The dryer heater with low insulation normally causes the fault on the drying cycle bit if it’s happening on the wash cycle is normally the board……and it’s m not cheap !!!
