Neff W/Dryer, no spin?
  • #72343
    WK61420GB/01 Washer dryer.
    Initial complaint of no spin, and a clicking noise.
    Set to spin, it drains for the usual 30/40 seconds and then cuts out completely, pump, everything.
    Set to wash and noticed at once that it is only tumbling anti clockwise ( from front) and the clicking noise is from the PCB relays.
    Never seen this fault before, suggests control PCB fault, unless you know better. 😉
    PS. Motor perfect, fitted new 18 months ago.
    #384256
    Re: Neff W/Dryer, no spin?
    This is an old SIEMENS Jim and I’m pretty sure the PCB on the baseplate is your problem. Expensive fix. 😥
    #384257
    Thanks Martin, I will convey the news to the customer, a friend (at least for now) of mine for over 35 years. 🙁
    #384258
    timdowning
    Do check for dry joints on the board. Did one a few months back.
    #384259
    Was this the PCB in the base or the facia/control PCB Tim?
    Hollytree_Technical
    Sounds as if one of the relays has a dead contact, if you are feeling brave you could try changing them.
    Jem
    #384261
    Soooooooooooooooooooooo,
    Is this on the PCB in the base or on the facia control PCB?
    timdowning
    Base.
    #384263
    Thank you.
    #384264
    Spot on Tim, just one dry relay joint, it’s a real pig to get this board out but it was well worth the effort. 8)
    Thanks.
