Neff W5320X0GB Will not spin in the spin and rinse cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Neff W5320X0GB Will not spin in the spin and rinse cycle
  • #102154
    Paul0729
    Hi my Neff W5320X0GB fills and drains without a problem but the drum will not spin during the spin/rinse cycle. Any help diagnosing the problem will be greatly appreciated! Thanks.
    #487755
    does the drum turn at anytime ?
    I would check brushes first
    Paul0729
    Thanks for the quick reply Dave. I’ve just taken another look and I can now see that there is power to the machine, but it doesn’t fill with water nor does the drum rotate at all! What do you think I should do please?
    #487757
    does the door lock ?
    Paul0729
    Yes. And when you turn the machine off the door unlocks after a short delay.
    #487759
    select spin only without rinse and see what happens. give it 5 mins as drum does not turn at first
    what am trying to do is find out if anthing works at all
    at the moment its got all the makings of a board or door lock fault
    Paul0729
    Hi Dave. Tried that and nothing happened – the drum didn’t move after 5 minutes.
    #487761
    ok check motor brushes
    does not normally happen on Bosch type machines but on some machines if brushes go machine wont run
    also try disconnecting both heater wires and see if anything changes
    Paul0729
    Hi Dave thanks for the advice. I’m struggling to move the machine out of its built-in position so I’m just going to have to call a person I know who should be able to help. You’ve been very kind with your advice today. Thanks again.
    #487763
    andyjawa
    IF the brushes are worn out there are two types it could originally have been fitted with: the usual 00154740 (or just 154740) genuine are £23.72 a pair. OR could be fitted with a Seimens motor which uses 00173028 (173028) but those are £68.03 as read off Neff`s own website which is depressing since the trade price is about 35 quid plus vat a pair.
    The 154740 ones can be got as pattern parts and they will vary from 3 to 4 quid a pair off ebay….my advise is do not buy those. And another commonly see pattern pair at roughly 7 to 10 quid which are better than the 3-4 quid ones but given it is an expensive machine I would only go for the genuine ones and there is a technical reason why. With the 173028 type, which you could well have fitted, I do not think there is any other option but those as genuine parts. These are white plastic screw on cartridged brushes and all will have a R raise moulded letter on them.
    IF it is brushes I would insist on the genuine parts. I`ve told you how much they are via Neff website so you know how much you should expect them to be. Best of luck.
    #487764
    Paul0729
    Issue resolved. The door seal was leaking and water collecting at the bottom of the machine was tripping the flood-prevention cut-off switch. I replaced the seal and the machine works perfectly now.
    #487765
    andyjawa
    A damn leak. Great U sussed it. You might want to copy and paste the bit about brushes though and print it off for the future.
