Neff W5420x0gb/14 Washing Machine PCB blown
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff W5420x0gb/14 Washing Machine PCB blown
  • #64415
    Twoten
    The above machine was reported as dead.
    On testing I have found the PCB blown. The chip and track beneath the capacitor to the right and the resistor to the left have gone.
    I motor and valves test out OK. The drain pump is reading 185? across the windings.
    The only other thing I can think of is the interlock but there are no signs of heat or damage and it’s not short circuit.
    Does anyone have any ideas on what could have caused this to blow?
    #357026
    Pigpen4
    Re: Neff W5420x0gb/14 Washing Machine PCB blown
    Have you tried tracing the damaged track / chip / resistor tracks back to a connector, then seeing what component goes to that connector?
    #357027
    Twoten
    Pigpen4 wrote:Have you tried tracing the damaged track / chip / resistor tracks back to a connector, then seeing what component goes to that connector?
    I was unable to trace this back to a specific connector.
    #357028
    What about heater area?
    Mike.
    #357029
    Twoten
    There wasn’t any fault with the heater, this checked out OK.
    #357030
    Twoten wrote:I was unable to trace this back to a specific connector.
    The photo shows the nearest connect being that 7 way block, so whatever that goes to has to be suspect. The burnt resistor and blown chip would indicate a polarity clash rather than an earth leak. 😕
    #357031
    Twoten
    I’ll take another look.
    Thanks.
