NEFF W5420X0GB/30 Washing Machine Beep & LED Error Codes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries NEFF W5420X0GB/30 Washing Machine Beep & LED Error Codes
  • #81872
    jontymox
    Good afternoon all,
    Could anyone let me know what the following codes relate to?
    There are two vertical rows of led’s; one row of five relate to spin speed,(1200,1000,800,400 and Rinse Hold) and the other row relates to the wash progress, (Wash,Rinse,Spin,and Ready)
    Having set a programme, after around one minute, the m/c beeps three times, and the 400, Rinse Hold, and the Rinse led’s flash continuously.
    The door does not lock, although the interlock is fine.
    A table in the handbook shows several error code sequences, but no the above.
    Thank you,
    Jonty
    #417963
    Re: NEFF W5420X0GB/30 Washing Machine Beep & LED Error Codes
    What have you checked on the machine so far Jonty?
    #417964
    jontymox
    Hello Martin,
    I haven’t been able to test too much, as I was hoping to ascertain what the machine is trying to signal.
    As mentioned, the door does not lock, so tested it.
    Also ensured filter/housing clear, as customer thought the three beeps relate to drain problem.
    The machine will not start on any programme, so a little limited until error codes verified.
    jonty
    #417965
    I don’t recognise the error code and would wade in and check motor, heater etc as the way to go.
    #417966
    jontymox
    Thanks Martin,
    Will return, and investigate further.
    Do you, or anyone know if a motor fault could prevent the door interlock from functioning?
    Regards
    #417967
    I wouldn’t have thought so.
    #417968
    jontymox
    Mmmm,
    Hopefully I can obtain these error codes, which would be beneficial.
    jonty
    #417969
    jontymox
    p.s.
    Does anyone know where these codes can be obtained from, other than
    NEFF/Bosch/Siemens, who will only inform their own engineers of such codes.
    jonty
    #417970
    jontymox
    Good afternoon,
    Having checked the wiring harness, and connections, I deduced that the power module was faulty.
    Renewed above yesterday…all well.
