Neff W543BX0GB/02 washing machine F23.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff W543BX0GB/02 washing machine F23.
  • #103433
    Twoten
    F23 Fault reported on the above machine.
    The fault displays as soon as the machine is switched on and the drum rocks a bit.
    According to the fault codes this refers to water in the base.
    The base is dry and the anti-flood microswitch tests OK.
    Is there anything else to consider for an F23 fault?
    Thanks.
    #493147
    is the anti flood sw normally open or closed
    if its closed then check continuity and connection to board
    also saw a brief poss heater error but cant be certain
    Twoten
    Thanks Dave,
    The switch is normally closed. It tested OK back from the board and I tightened the connections.
    I’ll check the element next.
    Thanks.
    #493149
    you could also try a reset and see if it makes any difference
    dave
