NEFF washer Dryer Draining Issues – No error Code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum NEFF washer Dryer Draining Issues – No error Code
  • #63764
    gingerkaratejoe
    NEFF washer/Dryer doesn’t drain and so doesn’t go into spin stage.
    No error code given by machine (Previously had E-06 tha points to a pump blockage)
    Have drained machine and checked pump fan at bottom left and there is a magnetic resistance every 1/4 turn suggesting pump is fine.
    Checked pump fan spins when cap left off.
    Have also disconnected outlet hose and blew through confirming no blockage.
    Have tried spin cycle now that machine is empty of water and although the machine tries to kick into a spin, it doesn’t manage. There are also a lot of relay clicks through the 15minute cycle.
    Is there another pipe that could be blocked?
    Have read elsewhere about brush replacement but don’t want to go down that route quite yet.
    Cheers
    G,
    #354836
    don
    Re: NEFF washer Dryer Draining Issues – No error Code
    Hi G
    For the Neff guys to be able to help, you will need to post up the all important ENR and FD number.
    Don
    #354837
    gingerkaratejoe wrote:Have read elsewhere about brush replacement but don’t want to go down that route quite yet.
    I would seriously suggest this is the likely fault based on what information you have given us so far. I take it that you’re not getting an E06 error right now and that you just stuck that in to confuse the current issue maybe? 😕
