Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Neff washer/dryer – dryer not working
- This topic has 7 replies, 2 voices, and was last updated 19 years, 5 months ago by
peterirving1.
November 2, 2006 at 3:36 pm #22225
peterirving1
ParticipantNeff (13 years old) tripped thermostat on drying – reset thermostat, still not drying. Replaced thermostat, still does not work, so cannot be thermostat! What next? Symptoms – dryer provides heat (excessive?) for, say, half an hour after thermostat reset/replaced, but thermostat then trips with result that washing still wet and cold. Everything else fine – washing, spinning etc.
November 2, 2006 at 5:33 pm #194105peterirving1
ParticipantShould have added that it is E No V4280G1GB/01 and model No GD5062.11, if they help.
November 2, 2006 at 8:35 pm #194106gegsy
ParticipantRe: Neff washer/dryer – dryer not working
Hi peter
I would suspect a lint blockage in the dryer manifold and only a strip down of that will confirm. Have you checked the heater is intact and that the dryer fan is turning correctly also?
I take it it was the re-settable thermostat you changed and not the sensor on the opposite side??
Un-plug appliance if investigating further :plug:Regards
November 2, 2006 at 10:48 pm #194107peterirving1
ParticipantGreg – many thanks.
The replaced item was Part No 032604 “limiter-temperature” which has a red reset button – unfortunately made no difference.
The dryer fan appears to be working OK and the heater looks intact.
I will try stripping down the dryer manifold (first disconnecting the power!) and remove any blockage – if I have any difficulty with this I will get an Engineer to do it.
Regards
Peter
November 2, 2006 at 10:52 pm #194108gegsy
Participantpeterirving1 wrote:……… and the heater looks intact.
It may look ok but a test with a multimeter will confirm.
Off the top of my head I would expect a reading anywhere from 20-30 ohmsGreg
November 2, 2006 at 11:08 pm #194109peterirving1
Beginning to look complex for a layman. Definitely worth an Engineer to look at it.
Peter
November 2, 2006 at 11:09 pm #194110gegsy
Hi Peter
Look no further than the engineer link below 😀Greg
November 6, 2006 at 10:25 pm #194111peterirving1
ParticipantFault found – blockage of duct providing air to fan. Now washer and dryer both working as normal – many thanks.
Peter
