NEFF WASHER DRYER ERROR 13
  • #76430
    funkyboogy
    MODEL V6320X0GB/01
    error been happening for about 2 weeks
    customer was able to clear the fault by unplugging and switching back on – machine would work ok but would leave 1 minute on screen , she just pull the door cord at pump to get door open ..
    now as soon as its switched on E13 comes up – pump runs for 20 seconds and then it stops .
    anyone know what error code is … pump runs ok , no blockages etc ..
    also read somewhere that it might be the dryer reset toc , had a look and this was ok ..
    can anyone advise the reset procedure on this
    cheers ally
    #398333
    timdowning
    Re: NEFF WASHER DRYER ERROR 13
    Think this is dryer heater low insulation. Like the AEG machines.
    Did you check insulation?
    #398334
    funkyboogy
    yes insu res was >1000 ,
    its a bit of a weird one ..
    cheers ally
    #398335
    E13 is a door interlock problem but from the info given so far I would think it is poor motor insulation causing the fault.
    #398336
    funkyboogy
    cheers martin
    will have another look , it funny you should say door lock
    as it does lock makes a clunk sound … then about 5 seconds later it shows error code ..
    customer is think about a new machine .. more money then sense its only 2.5 years old
    #398337
    nomadPaul
    The E13 is certainly the door lock error code but as mentioned earlier , it can be low dryer heater insulation. IIRC , one possible test is to put a load in to dry and after appprox 20 mins and then pause it…..if the door lock error code now appears , its related to the dryer side.
