Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Neff washer / dryer not heating – again.
- This topic has 3 replies, 2 voices, and was last updated 5 years, 2 months ago by
IanBill.
January 18, 2021 at 3:04 pm #98979
IanBill
ParticipantHi, and thanks in advance for any help.
NEFF V6320X0GB/03
So, my unit stopped heating last year and I called someone out to check it over – he reset the limit stat, said if it went again the stat would need replacing. I wasn’t very happy as a limit stat generally trips for a reason unless it’s failed, and I don’t see how you can tell that unless it doesn’t reset at all. I’m pretty competent with mech / electrical engineering but domestic appliances are a bit of a mystery so far.
Anyway, logically this pointed towards lack of air flow, obstruction, temp stat out of limit etc so I did a strip down. The condenser was virtually blocked, and the hot air duct had some lint in and around the heater so after cleaning it and resetting the stat it worked fine for a few months. It’s now tripped out again and before I strip it out again I’m looking for some help please.
Specifically,
Anything else I need to clear out apart doing what I’ve already done?
How can I check that the fan is working properly? – is it just on / off or can it vary in speed if it’s faulty?
It struck me that if the re’s a limit stat, there’s likely to be a control stat / sensor somewhere which I don’t recall seeing. Is there one, and where is it likely to be?
Given that I virtually have to take the kitchen apart to get at the thing, is it worth replacing the limit stat and the control sensor (if there is one) just as a belt and braces precaution?
Any help greatly appreciated!
January 19, 2021 at 12:01 am #474580electrofix
Moderatorthere will be air sensors and probably more than one
but first check the fan is clear and turns freely and no blockages
part lookup here
https://www.neff-home.com/uk/service/care-protection-and-parts/spare-parts
January 19, 2021 at 9:34 am #474581IanBill
Participantelectrofix wrote:there will be air sensors and probably more than one
part lookup here
Thanks Dave, I can see the sensors now. Do you think it’s worth replacing them? I’m guessing they’re not easy to test as they will have a varying resistance…..
January 19, 2021 at 10:04 am #474582electrofix
Moderatorproblem with neff is we dont have tech info, normally we have a table of temperature and resistance
as for changing them, well you wont know if thats the fault till you do
