Hi Guys,
I have the above w/d which fills (seems to fill to about right level) on start then just sits there for ages (i know some m/c’s sit dormant whilst heating but this happened on a 40 / 60 & 90 degree and i waited a good 10 – 15 mins each), if you press start (move it on in prog to rinse from wash) the drum immediately kicks into life as with all the other parts of the cycle. I have checked the heater – all fine, there is continuity on all solenoid valves, The brushes seem ok but only had quick check as spins etc fine other then the begining. The crazy bit is once i’d finished checking the above i but everything back together and it worked fine, Has anyone come across this b4? Any ideas What i could have moved or touched to make it o.k or should i this down as a board fault?
Thanks.
Paul.
