built in neff E-NR V5360XOGB/01 door locks starts to fill then comes up E14 on spin locks pumps drum action then E14
any ideas as its in rented and will be a sod to get out and the landlady doesnt want to spend much so I dont want to get involved without at least a possibility of a result. I see on the error code thread nct on the dryer listed but would this cause the above fault at the start of a wash?
Whenever most electronic microprocessor controlled machines start up they error check all components before starting any programme option, and issue an error warning or code if a fault is located. 😉
