Re: Neue dishwasher
Soppy little pressure switch fitted to these and most very late Lux dishwashers…..
Completely empty all water from the sump; remove door skin; unclip plinth front cover, remove plinth frame. Look at the sump unit and just to the left of centre and up under the tub you will see two very thin wires go up to a little item pushed into the side of the sump; it is white plastic, about 5cm long and has a dome in the middle. It is secured to the sump with a small plastic barb that has to be prised downwards and the pressure switch can be slid out and unplugged from loom.
Clean out the hole into the sump, the rubber gasket and try to clear the switch by tapping the open end onto your palm. Sometimes food bits come out and the switch can be saved, sometimes not. Fortunately, they are quite cheap and quite fallible so that’s good news….. 😉 I am now keeping this item as van stock as I’ve had several fail and they seem to be regular fit to Lux based stuff.
Hope that helps,
Steve.
