Neue dishwasher Idsh602W – four flashes and drain out
Home Forums Trade Technical & Spare Parts Forums Neue dishwasher Idsh602W – four flashes and drain out
  • #96770
    twicknix
    This cloned Electrolux dishwasher has me stumped. Owner says that it washed for 15 mins then terminated.
    I went to visit the dishwasher and carried out express wash to see what’s happening. Ran it for 30 minutes with no issues until I reset the dishwasher after assuming that there’s nothing wrong with it.
    Checked the base, clean as a whistle. Heater works, blooming hot as the temperature probe showed up a reading of 60 degrees. Not used to working on dishwasher that produce so much heat, steamed up my glasses – couldn’t see a thing! Having said that it is within the normal temperature setting of 65 degrees.
    Am I missing something here? Which pressure sensors are likely to be the problem? I thought maybe the sump pressure sensor as after I cleaned it up, it seems to have made things worse(?).
    Slightly off topic – Them Electrolux dishwashers in general doesn’t fills me with confidence, do they make the new ones so complicated to fix? I have a sneaky suspicion that some are prone to leaks after few years which made my job harder to trace the leaks
    #464764
    this unit was the subject of a modification on the pressure sw due to clogging
    4 flash faults are pressure sw problems
    can send you the info if you let me have an email address
    kit you need to fit is
    https://shop.ukwhitegoods.co.uk/4055346060-pressure-sensor-kit
    twicknix
    Thank you, you got mail…[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://www.ukwhitegoods.co.uk/forums/core/core/images/smilies/thumbsup.gif”}[/IMG2]
    #464766
    no I havn,t
