Re: New Bosch Free standing dish washer
mike100 wrote:I thought would then slide off. No way, totally jammed on.
Remove the 2 Torx20 screws at the rear
Press up the 2 locking levers at the front & lift up worktop
Push back to fully remove
mike100 wrote:It has a solid plastic base so no access there. It has got to be from the front for the pump.
To access the pump, tilt m/c backwards.
Place screwdriver into the guides locate under the front plastic plate and release catch downwards, then lift plate up and away.
Remove 2 Torx screws from front metal plate and lift plate clear.
Remove pump connector
Release locking latch whilst rotating pump slightly clockwise
Pull pump forwards and clear.
HTH?:D
