New double electric oven-fan doesn’t turn off
Home Forums Public Support Forums Help And Support Cooker And Oven Forum New double electric oven-fan doesn’t turn off
  • #70339
    BexH
    Hi, can anyone provide any advice please?
    Just had a new double built under electric fan oven installed & since the electrician connected it to the power supply the fan has been blowing out cold air. The oven isn’t turned on and all of the lights are off. The electrician said its usuall for the fan to be on for 30-40mins when the power is first connected but it’s been 2hrs now! If I turn the power supply off via the red power button on the wall the fan stops but I was under the impression that it was not necessary to do this when the ovens not in use.
    Does anyone know what I should do to turn it off without turning off the electric supply? Or if it sounds faulty?
    Thanks in advance.
    #377839
    SAMURI
    Re: New double electric oven-fan doesn’t turn off
    This sounds like a fault or may be an installation problem.
    If it hard wired in the electrician may have dropped one of the electrical links on the back of the cooker on the mains block.
    Bob
