new format aeg condensor driers
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries new format aeg condensor driers
  • #87687
    gandh1
    seen 2 identical models now, approx 2-3 years old, put on sensor dry, and it takes up to 5 hours to dry, put on timed dry for 30 mins, backplate of drum gets too hot to touch after 3 mins, then cools enough to be comfortable after approx 10 mins, then it gets red hot again a few mins later, then cools down again.
    Presuming the overheat stat is cutting in, cant find any reason why its overheating in the first place though, as condesor box and airflow is all clear. any known issues as reviews seem to indicate mass problems after 3 years?
    When i say new format i mean these all have the twin-pcb design, with the std control panel one and a black plastic housing side module, which im guessing is used for motor control?
    #435680
    Re: new format aeg condensor driers
    if you had a prod number could look up tech to see if any problems listed
    gandh1
    i do have them somewhere int he shop, i know they’ve not been released to connect as ive already looked on mediator tho!
    #435682
    simon26r
    Product number .. sod connect
    #435683
    simon26r wrote:.. sod connect
    I agree with the last speaker!
