new format bosch smv50e00gb/31 not cleaning in front???
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries new format bosch smv50e00gb/31 not cleaning in front???
  • #78082
    gandh1
    as above. been out to look at a machine a kitchen fitter has “imprisoned” into the kitchen. So though as it will be a sod to extract, I’d see if anyone, nomad-pauly etc, has had this issue.
    Seems appliance will spin lower wash arm, but not upper. 1/2 load isnt permanently lit, and assuming a blockage, but as aforementioned. this is almost a kitchen unit dismantle to remove, so would appreciate any in-situ repairs that can be attempted first 😛
    cheers guys in advance
    #404411
    nomadPaul
    Re: new format bosch smv50e00gb/31 not cleaning in front???
    Is the appliance actually switching between the two arms but the top won’t rotate or is it not switching at all ? The time between switching is longer on these new models , approx 2mins about so you do have to wait longer for the change.
    2 possibles . 1- If no switching the diverter may be jammed. 2 – if it switches but the top arm doesn’t rotate but just sounds like waters gushing out of it , it may need a ‘rail’ mod fitted at the very back. There is a fault where the top basket doesn’t fully engage on it’s rear coupling because the back wall of the tub is too flexible. The rail mod strengthens the rear tub.
    The crux is whether it’s actually switching in the first place!
    #404412
    gandh1
    theres defo water coming through the upper basket spinner, but its like theres not enough pressure to turn it, so it sounds like it might be the rail issue. is that a f.o.c bosch modification or something wed need to order?
    #404413
    gandh1 wrote:theres defo water coming through the upper basket spinner, but its like theres not enough pressure to turn it,
    Have you lifted the top spray supply pipe to see if the water point to the top spray has fully opened though (as Paul referred to) ?
    #404414
    nomadPaul
    There is a way to check but you need the appliance out to do it. Basically you get the appliance up and running and when you’re sure the water is going to the top arm , apply light pressure on the back , approx 26cms down. If the spray arm then starts rotating , you’ve confirmed it needs the rail.
    #404415
    What’s the mod number Paul?
    #404416
    don
    Martin wrote:What’s the mod number Paul?
    It’s in the thread title 😉
    Need to visit Specsavers Martin :clown:
    Don
    #404417
    Part number of the modification Don. 😉
    #404418
    don
    Martin wrote:Part number of the modification Don. 😉
    :boops: :eeek:
    I should have read the whole thread properly rather than just skimming it. My apologies Martin.
    Don
    #404419
    No worries Don.
    (Mod = Model or Modification or like me a Mod in the 60’s wearing a parka on my Lambretta) an easy mistake to make after all! 😉
    #404420
    gandh1
    nomadPaul wrote:There is a way to check but you need the appliance out to do it. Basically you get the appliance up and running and when you’re sure the water is going to the top arm , apply light pressure on the back , approx 26cms down. If the spray arm then starts rotating , you’ve confirmed it needs the rail.
    Looks like im gonna have to dig out my crowbar and tyre lever then
    #404421
    wizard
    Before you do that, just check the top spray arm feed is properly clicked into place behind the bottom spray arm. Had one recently that was loose with this symptom. Wiz
