new indesit washer inst prob
Home Forums Public Support Forums Help And Support Washing Machine Help Forum new indesit washer inst prob
  • #16979
    mrspapalaz
    Hi guys, have you ever come across this problem? I dont have the model number yet, but a friend purchased an indesit WM. They installed it in the same place their old machine went but when they ran it they found that the cold water tank in their loft was overflowing! Who would you call out? plumber or WM repair man? Indesit will charge a no fault call out fee if its their plumbing. Any advice appreciated.
    p.s. they live in a bungalow 😕
    #172383
    Goatboy
    Re: new indesit washer inst prob
    I don’t see how the washing machine is doing that 😕
    And if I was in his shoes, I’d ring a plumber. But, if I was in his shoes, I wouldn’t have bought an Indesit 😉
    #172384
    Dave_Conway
    It’s pure coincidence I think, the ball valve washer has probably failed in the loft cistern.
    Plumber required 😉
    #172385
    Goatboy
    Hi Dave :wave:
    10000 posts eh? Wow!
    #172386
    Dave_Conway
    :wave:
    Yep, sad eh 😉
    #172387
    whitevanman
    Dave_Conway wrote:It’s pure coincidence I think, the ball valve washer has probably failed in the loft cistern.
    Plumber required 😉
    Just a thought are they using now using a Y piece after hot/cold valve with one pipe to soap box, (SUK – had same problem and converted Y peice with non return valve).
    #172388
    mrspapalaz
    cheers guys, thought it might be an unfortunate coincidence aswell. Will pass on advice,
    many thanks 😉
    #172389
    bobokines
    I would imagine that someone has inadvertantly connected your hot supply to the cold supply and the mains pressure is pushing the hot water supply backwards through the system and overfilling the cold tank in the loft.
    Check that the machine has been installed with the blue pipe to the cold valve and the red(or grey) pipe to the hot valve. If a cold fill adapter has been fitted then it should be connected to your cold supply and both hoses connected to that. The hot tap should not be used at all.
    If the machine is a cold fill only, ie, there is only one valve on the machine, then there should only be one hose connected to your water supply and again the hot tap should be ignored.
    Bob
