New ISE dishwasher door wonky
Home Forums Public Support Forums Help And Support Dishwasher Help Forum New ISE dishwasher door wonky
  • #75840
    bmadgett
    Had a brand new ISE D243W dishwasher fitted today, which seems to run ok but the door catches slightly on the left metal surround as you close it and it’s visually a bit shifted over to the left of the machine so the edge showing around the door is uneven. Basically, it doesn’t look or feel hung quite straight.
    Is this something we should complain about? Or is it possible to adjust the door alignment yourself?
    #396325
    Re: New ISE dishwasher door wonky
    Sounds as if it isn’t completely level with, from what you say, the RHS foot needing raised or the LHS one dropped slightly.
    A lot dishwashers can be like that, they need to be as close to level as possible.
