New noisey Bosch KGN34X00G Fridge / freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum New noisey Bosch KGN34X00G Fridge / freezer
Viewing 4 posts - 16 through 19 (of 19 total)
  • #192596
    tubafan
    Re: New noisey Bosch KGN34X00G Fridge / freezer
    Finally have our replacement fridge-freezer (first replacement was rejected as it arrived damaged).
    Compared to the first one it is almost silent most of the time – so if you have one of these and it sounds like a tractor then compain to Bosch!!
    Hopefully it will work for more than 3 months without freezing-up like the old one.
    I also note that the new one has “/06” after the model number whereas the first one we had was “/02” – don’t know if this is anything to do with the modification level?
    #192597
    Gerard
    I have posted about about a problem with my KGN33V00GB previously and was linked to this thread.
    To re cap, we had the temp increasing in the fridge and was pointed to the above fix.
    I have though, not contacted Bosch, as a defrost in April cured the problem……yet it is coming back! The fridge temperature is rising with no change in activity.
    Is there anything I should know from the experts here to quote to BSH so they don’t try and fob me off when they come to fix it?
    Should I let it get warmer before I call them, it is definately warmer/not as cold as when it was defrosted?
    #192598
    gegsy
    If you contact Bosch, Im sure they will have some answer for you 😉
    Gerard
    We had the engineer call and fit the mod kit.
    Whilst it took a while to drop it’s temp, it has done.
    Thanks for all the help on this forum.
