New oven and hob help – Bosch or Neff
Home Forums Public Support Forums Buying Advice New oven and hob help – Bosch or Neff
  • #80058
    Teddox
    Hi All,
    I am in the process of sorting a new kitchen and would like some help with the Neff / Bosch choices. I need to get in an electric built under double oven and then a 5 burner gas hob on top. So far I am looking at the Bosch and Neff ranges with a budget around the £600 to £800 mark for the oven and up to £350 for the hob. The ovens I have been looking at are the U17M42N3GB (Neff), U17M52N3GB (Neff), HBN43B250B (Bosch), HBN13B251B (Bosch). The hob brand will match the oven brand so it will be something like the Neff T26S56, T25S76N0, T25S56N0GB or the Bosch equivilent.
    From looking at the specs it seems the U17M42N3GB and HBN13B251B are pretty much exactly the same bar the name and the same goes for the other two.. all very confusing 🙁
    #411519
    don
    Re: New oven and hob help – Bosch or Neff
    Teddox wrote: all very confusing 🙁
    Not at all 😉 Bosch and Neff are both part of BSH group of companies. Each brand has it’s own identity, Neff have oven tap tap controls and small clock display while Bosch have round controls and larger clock displays.
    Both brands give exactly the same oven capacities, same grill pans and both are capable of taking taking the same accessories.
    The above aside you just need to decide on the features and functions you require.
    HTH 😀
    Don
    #411520
    Teddox
    Thanks for the help!
