Home › Forums › General Trade Forum › New oven won’t fit because of Gas pipe – Options
- This topic has 7 replies, 5 voices, and was last updated 4 years, 9 months ago by
centigradeltd.
June 11, 2021 at 8:23 am #99659
centigradeltd
ParticipantWe have gone to fit a single electric oven and the shape of the new oven means the gas pipe to the hob stops it from sitting flush.
Is there an oven specification that allows for this when buying or is it just unlucky
June 11, 2021 at 10:56 am #477266electrofix
Moderatorhad this a few times. It seems manufacturers are trying to make the cooking areas bigger and therefore maximize the space in the unit
what oven did you buy /
June 11, 2021 at 11:40 am #477267don
ModeratorI get this almost every day 🙁 the best ones I know of is the Indesit IFV5Y0IX as it has the cut away to allow for the gas pipe. Or you keep what you have and have the gas pipe reconfigured to fit around the new oven.
Don
June 16, 2021 at 8:14 am #477268centigradeltd
Participantdon wrote:I get this almost every day 🙁 the best ones I know of is the Indesit IFV5Y0IX as it has the cut away to allow for the gas pipe. Or you keep what you have and have the gas pipe reconfigured to fit around the new oven.
Don
Thanks Don, I thought there was a spec to choose. Currys have a filter option for “flat back ovens” which I thought might be an indicator of something am missing. Turns an easy job into a pain!
June 16, 2021 at 8:15 am #477269centigradeltd
Participantelectrofix wrote:had this a few times. It seems manufacturers are trying to make the cooking areas bigger and therefore maximize the space in the unit
Thanks Dave, it was an Indesit. Turns out the gas pipe was using a water valve to turn on and off so lucky we noticed really!
June 16, 2021 at 8:16 am #477270electrofix
Moderatorsee all sorts, had a hob fed with a rubber pipe last week
September 14, 2022 at 4:41 pm #477271grazzamongrel
ParticipantI come across this so often and struggle to find a suitable oven to fit with a ‘cut away’ to allow for the gas pipe. Beko seem to be a safe choice with their Diagonal cutaway at the top ro allow for pipework but they are also a quite a deep oven and as found out yesterday a cabinet that has been badly installed with a 54cm depth just isn’t good enough and turned a simple install into a sweaty nightmare
December 28, 2022 at 1:38 pm #477272cornwell40
ParticipantRegular issue, usually tell them to get a gas man round to sort the gas elbow out.
