new range wpool fault codes
  • #42711
    simtoms
    does anyone know the fault codes for Wpool Pro Series 6, mod HDW0614wg please? Thanks, simtoms.
    #274586
    Flyman
    Re: new range wpool fault codes
    F01 – No Fill.
    F02 – Aquastop Failure.
    F03 – Drain error.
    F04 – Too long to heat.
    F05 – NTC failure.
    F06 – Motor Tacho.
    F07 – Motor control triac.
    F08 – Heater circuit error.
    F12 – Heater circuit error.
    F13 – Door lock error.
    F14 – Eeprom error.
    F15 – Drum up Circuit Missing (only for top loaders with Drum up Circuit)
    F18 – Excess Foam detected during wash cycle.
    F21 – User interface error. (only with smart user interface).
    F23 – Pressure switch failure.
    F24 – Overfill.
    F26 – Pump Triac failure.
    F27 – Reversing relay failure.
    F28 – Tapped field faiure.
    F31 – Blocked drum detected. (only top loaders).
    F40 – MEB communication failure or ambient temp below 5 degrees C.
    F41 – MEB control board failure.
    F42 – Steamer component failure.
    F43 – Steam valve failure.
    #274587
    simtoms
    Thanks very much for that, a great help!
    simtoms.
