Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › New tumble dryer hose too big for existing vent
- This topic has 3 replies, 2 voices, and was last updated 18 years, 11 months ago by
sylwright.
April 18, 2007 at 10:56 am #26707
sylwright
ParticipantI have just taken delivery of a Hoover HNV380 Tumble Dryer to replace an old Hotpoint one which was already vented through a brick wall. Unfortunately the diameter of the vent hose which came with the new dryer is much bigger than on my old machine and won’t fit my existing vent duct. Also because its so big it makes it difficult to fit the dryer into a corner, have had to leave room at the side for the vent hose, if I put it at the back of the dryer then it sticks out too much. This causes problems because it sits on top of my washing machine and if I pull that forward then I am unable to open the door of the utility room.
I am kicking myself now as if I had known about this I would have just ordered the condensor version but as I already had a vented dryer I assumed it would into place just the same.
Any suggestions gratefully received.
April 18, 2007 at 12:30 pm #211129Martin
ParticipantRe: New tumble dryer hose too big for existing vent
sylwright wrote:Any suggestions gratefully received.
The only correct solution would be to either relocate the dryer elsewhere or install another vent kit through the wall to match up. 😕
One of these required I reckon……..
April 18, 2007 at 12:34 pm #211130sylwright
ParticipantMartin wrote:
sylwright wrote:
Any suggestions gratefully received.The only correct solution would be to either relocate the dryer elsewhere or install another vent kit through the wall to match up. 😕
Thanks for the advice. It isn’t possible for me to re-locate the dryer, and instead of installing another vent through the wall wondered if there was some kind of reducer to fit on the large pipe to enable it to fit the smaller vent duct. Or if its possible to fit a smaller vent hose on the new dryer by way of a reducer.
April 18, 2007 at 12:50 pm #211131Martin
Participantsylwright wrote: Or if its possible to fit a smaller vent hose on the new dryer by way of a reducer.
Why not attach this to your wall over the existing vent hole? As you can see it caters for various hose sizes and you attach your new larger hose with a large jubilee clip or cable tie. It is available by emailing spares@ukwhitegoods.co.uk (quoting V/T46) 😉
