New Washer Dryer (or used) recommendations please…
Home Forums Public Support Forums Buying Advice New Washer Dryer (or used) recommendations please…
  • #57295
    lrs
    Our Ariston Margherita 2000 washer dryer has finally died after 8 years service (which judging by what I have read on here was bloody lucky!). I think it’s the control board but it makes such a noise i expect the bearings are also on their way and that pumping money into it now would be a false economy.
    After reading “The Great Washing Machine Swindle” I am not surprised as it sounds much like the car industry – wishbone bush gone – that’ll be a whole new wishbone then sir!
    I wish I had the money to buy a really good machine so I am erring towards a decent s/hand with good spares support.
    Can anyone suggest anything? I can stretch to £600 max
    thanks
    Julian
    #330518
    lrs
    Re: New Washer Dryer (or used) recommendations please…
    I decided to remove the pump cover and after taking out a load of coins started to suspect that may have caused the problem. No joy, wouldn’t do any program even a spin. I’ve long suspected the control board (it will only run program 8 initially then if you’re quick you can run and program after 8 has run its course – my wife has put up with this for a year !)
    Anyway I removed the control board connectors and reconnected and heh presto it’s working again !
    Still it’s clearly on it’s last legs and given it’s lasted 8 years with ZERO repair costs (even the belts original although i’ve put it back on numerous times) I think it would make sense to look at alternatives still.
    #330519
    don
    Is a washer dryer an absolute must? Best to have two seperate machines if you can 😉
    The modern washer dryers just don`t do what they say on the tin I’m afraid. The nearest you will get is the Miele which comes in at over a grand, next best would be the Bosch range and the Zanussi’s, after that eveything else. This article from our buying guide on washer dryers is a well worthwhile read.
    HTH 🙂
    Don
    #330520
    lrs
    Unfortunately no room for both appliances and the Mrs insists we need the dryer. It turned out the brushes on the motor had worn out – I replaced them – restarted and unfortunately it seems one of the inlets to the drain pump was blocked and after a pop and spark in that general area it’s now completely dead ! If the drain pump motor failed would that stop the machine even switching on? (checked fuse this is ok)
    thanks for the link re Washer dryers.
    cheers
    #330521
    DDSDDS
    think it is time to stop with your current machine and just admit it is dead if it has gone pop it is almost a certaintity that the board will have been taken out with it
    #330522
    lrs
    DDSDDS wrote:think it is time to stop with your current machine and just admit it is dead if it has gone pop it is almost a certaintity that the board will have been taken out with it
    I agree. Found a Bosch Classixx WVF 2402 used locally at a good price – how are these in general? Spares availability?
    thanks
