new world 7000 oven
  • #73637
    hdltd
    i want to totally disconnect the clock on a new world 7000 oven as the customer is elderly and swiches it onto automatic cooking so if anybody can give me the wing daigram to see what wires cotrol that side of the clock to remove the function i would be gratefull
    Many Thanks
    Norman v
    #388249
    Re: new world 7000 oven
    Why not just remove the knob that she is inadvertently using?
    I would assume most of the timer/control unit functions are internal to the unit anyway. :con:
    #388250
    hdltd
    as with all old dears the timer/clock really wants replacing as you cannot now set time of day or stop minute timer acting and alarm ringing so i just want to disconnect clock and leave it on manual for her i think its just finding the power out of clock tried taking her for a ride to local old folkes home but the bitch walked back so i am still lumbered
    #388251
    hdltd
    anyone got any thoughts to short out thewiresthat operate theauto cook side of the clock so i can do away with auto set and leave it on manaul please
    Many Thanks
    Norman
    #388252
    Not knowing the model but,assuming this timer is a stand alone clock, (rather than some pcb that controls everything) it will be a simple operation but you will need to work it out yourself. Of all the wires to the clock, 2 will be the power to the clock itself and the others conected to either a relay or mechanical contacts. if its single pole then there will only be one pair to short out, if double pole the their will be 2 pairs. I usually just replace one of each pairs spade terminals with a piggy back type (rated accordingly) and attatch the second wire to that.
