New World battery replacement
Home Forums Public Support Forums Help And Support Cooker And Oven Forum New World battery replacement
  • #14506
    derekf
    I have a New World Richmond Si600 cooker.
    The electrical ignition fails to function, and I can’t locate the batteries. Before I strip the cooker down, appreciate if anyone can point me to the location of these so I can replace them. Thanks.
    #159680
    Dave_Conway
    Re: New World battery replacement
    Depending on the version (model required CKG???) most Richmond cookers are mains powered ignition so there will be no battery.
    If that is the case, you’ll need to call a Corgi registered engineer to repair this for you.
    Check the repairs@ link below, should that fail, the Corgi website has a list of engineers also at:
    http://www.corgi-gas-safety.com
    #159681
    derekf
    Thanks for that, Dave. Unfortunately this cooker is definitely battery powered (CKG 21118) – there is a circuit diagram on the back of the cooker showing where the batteries are in the cct, but not the location of them.
    Have had the hob off, and the back plate, and can see wires disappearing to the base of the cooker – where I will be disappearing to shortly!!
    #159682
    Dave_Conway
    No need !
    The battery is in a case (plastic holder) left hand side right near the floor in the plinth, opening the oven door will make it easier to see 😀
    #159683
    derekf
    Found. Thanks for all your advice, Dave – much appreciated
