New world DW60 stopped working
Home Forums Public Support Forums Help And Support Dishwasher Help Forum New world DW60 stopped working
  • #87267
    scudo
    It suddenly started beeping after a wash and would not switch off nor select any of the programmes.It is not showing any error messages. Just in case it was the door operated switch was jammed I gently prodded it with a screwdriver, something went click and now the door does not `lock`
    Maybe I broke the switch (which I doubt) or it was not operating correctly hence the fault.
    As a new switch is quite costly is there anything I can do to check the interlocking door switch is the offending part.
    #434347
    Re: New world DW60 stopped working
    switch needs to be pulled forward again i use a peice of old wire coat hanger with a 10mm “L” shape at the end. hook it into the “U” of the latch and pull it forward
    scudo
    That doesnt pull it forward, I will try and get time to take the door off and access the switch for a good look.
    Does anything look broken?
    #434349
    the white plastic but you can see has a “U” shape that grabs the loop on the frame. all you have to do is get soething in the “U” and pull it ( down in the above picture)
    otherwise strip it out and roll the latch back into position
    its not broken its just in the locked position
    scudo
    ok thanks for the info I will I will give it another go tomorrow and if necessary strip it out for closer inspection.
    I will post back on the outcome.
    #434351
    scudo
    OK I have taken the switch but still unable to free without using excessive force,
    Images attached.
    #434352
    top picture
    pull plastic piece down so “U” shape faceing forward
    and yes it does take a bit of force it has to hold the door shut
    scudo
    Now sorted. 🙂
    I eventually released the spring and got it back to the proper position and then had a hard time of it to get that spring back on, but made a tool from some stout wire to assist me, with 2 hooks on the end to hold the `bar` and the spring and pull it up to where it is seated, and that worked.
    Done a rinse and a wash and so far working properly.
    Thanks indeed for your assistance.
    #434354
    scudo
    I thought post on this thread as I think my problem stems from my original post.
    Dishwasher works, BUT…….
    When I close the door it sometimes beeps once and then gives a double beep and turns off. It appears that the contact part that locks the door is not connecting properly as I can firmly hold the door in place (beeps once) but when I release the pressure it sometimes beeps twice for `off` I can usually get the cycle to work eventually.
    I cannot see any means of adjusting, anyone got experience of this?
    #434355
    either
    1 lock needs changing
    2 top hoop may adjust does on some dishwashers
    3 door is strained so wont close properly
    scudo
    Thanks for the reply Dave,
    I had a quick look and I think option 3 could be the answer, I will see if over the next day or two I can adjust whatever on the hinges as it does look as is if the alignment could be out.
    I suspect the lock is ok but will `test` by setting the washer and manually push in the switch (now that I know how to pull it back out re your previous advice). The metal hoop I have already tried and there is no apparent adjustment.
    #434357
    if the hinges have been bent you need to change them as they bend if door is strained
