New World DW60 (Stoves)
  • #49822
    geoff1
    This one is working at present but has intermitant fault of E3 ( ntc or heater Fault)
    Again circuit is fine from module through heater and there are no dry joints on module
    Anyone had a fault like this????
    Geoff
    #302445
    Jazzmeister
    Re: New World DW60 (Stoves)
    DW 60 sounds a bell….is it a haier type…if so check the 2 safety cut ots underneath 1 will be o/c
    Jazz
    #302446
    geoff1
    Thanks Jazz
    This uint is branded as a new world but has stoves model number and product code number on it – not sure if this is the same as the one you are talking about. Haier machines yet to be seen on these islands as yet.
    This type has a heater with pressure chamber attached. Micro switch makes to allow power to heater once motor has water up to pressure?
    Does this sound the same?
    Could not see any additional saftey cut outs? where are they located?
    Geoff
    #302447
    DW60 in ‘Search’ brings up some results.
    geoff1
    Had a good search but nothing there. Machine still working fine so customer going to let me know when it goes faulty again. Will post reply if I do get an answer
    Geoff
