I have a 2 year old New World 60GDOL cooker and the top oven can no longer get to temperature. I used an oven thermometer to check the temp and at gas 9, the internal temp stabilises at 150 degrees C.
The main oven has always run approx 2 gas marks higher than set but I was assured that this was because of the ‘gyroflow’ although the instructions gave no idea of what temp each gas mark should correspond to if they are anything above standard.
Any help greatly appreciated
Gyroflow ovens are usually set 25C lower and cooking times are reduced by 10 mins for every hour of cooking.
Gas mark 9 is app 250C FYI.
So I would imagine you either have a poor seal on the oven door or a faulty oven thermostat.
Please use the link below to find a Corgi engineer in your area to be safe.
